1 - 9 of 9 Posts
What I have:
K20Z1 engine, harness, transmission.
K20A2 (apparently) Hondata ECU.
1977 Fiat X1/9.
Hondata, in their usual style, essentially just told me to go jump in a lake. The tech guy said that the adapter harness to adapt an A2 KPRO to a Z1 harness is only good IN a 2005-6 RSX. He had no tangible explanation as to why this is so. He just did a Pontius Pilate: "we don't support that. You're on your own."
Because I already know that the Z1 A, B and E connectors plug in to the A2 ECU, it *could* be as simple as re-pinning the Z1 harness to A2 spec. I am already aware of the high-frequency v. low frequency speed sensors and am willing to take the chance since the high frequency sensor will merely send a higher-than-correct signal to the A2 ECU. I wouldn't *think* this would affect VTEC as long as the computer doesn't ask questions like "why am I going 500 miles per hour?"
Questions:
1) Has anybody used a Z1 harness with an A2 KPRO by repinning the Z1 harness?
2) Can anybody call BS on Hondata for saying that the adapter harness won't solve the problem outside of an actual 2005-6 RSX car?
3) Does anybody have experience to advise me on what I should do OTHER THAN "buy a 2002-4 harness and transmission?"
i currently run same setup. you can
a:repin z1 harness to 02-04 spec.
b:buy ktuned's 05-06 to 02-04 jumper/step down harness
after doing one of the above two you will need to run a vss converter to convert the 05-06 vss signal to 02-04 spec so ecu reads correctly(hybrid racing and ktuned sell these) side not if you can not repin harness rywire will repin it for $100 or less iirc. if you can repin yourself both 02-04 and 05-06 wiring pin outs are in the FAQ section
Thank you for your reply. I figured somebody had to have done this before.
What is the difference between K-Tuned's harness and the Hondata one that we paid for and didn't receive? The tech guy at Hondata (for what he is worth) told me that the adapter harness is only for 2005-6 cars and swore that it wouldn't work outside of a 2005-6 CAR. He gave no substantive reason, saying only that there would be electrical problems and that "we don't support that."
Does Hondata make internal changes to the A2 ECU for a Z1 car, or is this still truly an A2 ECU regardless of whether it was intended to go into a Z1 car or not? In other words, can I proceed with repinning to A2 spec regardless of what they did to the A2 ECU I have?
And does the VSS really need an adapter if I am not using a Honda speedometer? I am building the car with a Marshall speedometer, which I have to calibrate anyway. Does the VTEC really need a CORRECT speed signal, or does it only need to know that the car is moving?
Hondata's jumper harness was designed to be used in 05-06 RSX only. It converts all 3 ecu plugs from 05-06 to 02-04.
Our jumper harness is for swap cars and converts only 2 of the 3 ecu plugs.
This is because the third plug will be on your swap conversion harness and will already be wired correctly to 02-04.
· ...doesn't give a shit.
Technically, no. There is a setting in kmanager where you can set the VSS to a constant speed signal so VTEC will engage. I had that issue with my kpro where it wouldn't read the VSS and VTEC would not engage. All I did was change the setting in kmanager and it cleared that up to make sure everything else was working. However, I do not know if setting the VSS signal to constant will affect anything else in your application.
In my application, I have to route the signal wire from the VSS to the speedometer, then back to A18 to make the speedo work. Otherwise, the speedo does not work. On my first build, I wired the speedo exactly as Hondata's diagram prescribes and absolutely could not get the speedo to calibrate or VTEC to engage.
NOTICE: Thanks so much to Mike at K-Tuned. He has spent probably an hour on the phone with me today helping me sort out exactly what is going on. He was far more willing to help me sort out my problems with Hondata than Hondata was. That is service!
Good customer service is always appreciated. I am always a return customer when I am treated well.
In your first build, did you ever try changing the speed sensor setting? It's in parameters under the misc tab. There are 3 choices:
- Normal speed sensor
- Countershaft driven speed sensor (2005-2006 RSX, S2000, TSX)
- No speed sensor - provide constant speed signal
If you tried that, did it affect your speedo? Would you happen to have a link to the Hondata wiring diagram?
Discussion Starter · #8 ·
Timot,
This is MY first build with a Z1. The fabricator before me built a Z1 conversion, but he is gone and with him, whatever he learned about making the speedometer and VTEC work. I have since figured out how to make the speedometer and VTEC work regarding speedometer wiring.
I still wish I knew for certain if Hondata made any changes on pinouts to the ECUs destined for Z1 cars or if the necessary changes are 100% done in their adapter harness.
Timot,
I wish I could point you in the right direction. It may be worthwhile to talk to a Hondata dealer and ask them. It sounds like you got it to work though. What fixed it?
1 - 9 of 9 Posts
