Welcome to K20a.org. What is your project @NociEK?Did you get someone ?
You didn't ask me 😂. Anyway, if you want to get it done, do it your self, or find one reliable, competent, rational, knowledge-full, accurate, customer-service-orientated in that specific business that have time to do the job. Quite rare always, so DIY is most an optionhi, thank you for asking. No I went the same way as always. Do it yourself and you get wath you want. ;-)
Yes, you did, just joking. Would be great if you share your progressAs I remember I did.
Ok, in short right now,Yes, you did, just joking. Would be great if you share your progress!
You mean this 344-05-1410 - Springs, Retainers & Bases - Engine - Skunk2 Racing here? With the correct seat base and retainers? Stock stuff is not matchable with it, also the keepers need to be before the angle upgrade in 2004.set of Skunk2 twin springs and retainers...Ordered the Toda cams you suggested,
Yes, I have these with the right base. What are you saying? The "stock stuff", is it valves and keepers that don't match the Skunk spring if they are fitted in a PRB-1 head?? What is the problem, valve spring height??You mean this 344-05-1410 - Springs, Retainers & Bases - Engine - Skunk2 Racing here? With the correct seat base and retainers? Stock stuff is not matchable with it, also the keepers need to be before the angle upgrade in 2004.
Haven't measured that yet. What is the short coming below 39.2?? Spring bottoming out??Don't lower the installed valve spring height below 39.2 mm.
Do you say that I'm better of with the standard stocks springs???These spring have an almost similar high spring rate as the stock ones and cause quite a lot of pressure when fully open.
So ditch the Skunk springs for TODA 14750-F20-000 with stock caps and keepers??My recommendation is always using the TODA springs in addition.
No, the OE '04+ keepers don't match with the Skunk2 retainers, which are duty when you use their springs. The stock retainers don't match S2 Alpha valve springsYes, I have these with the right base. What are you saying? The "stock stuff", is it valves and keepers that don't match the Skunk spring if they are fitted in a PRB-1 head?? What is the problem, valve spring height??
No, I wrote the S2 springs have a high spring rate like the OE valve springs have it. These cams don't benefit from that high spring rate, it is just a force to overcome lost in friction.Do you say that I'm better of with the standard stocks springs???
That would be a very good plan. I buy only from Honda racing JPN (Camshaft - TODA RACING (toda-racing.co.jp)), but the part number fits. What valve springs do you have, the single spring or double spring?So ditch the Skunk springs for TODA 14750-F20-000 with stock caps and keepers??
Ok, good, thank you.No, the OE '04+ keepers don't match with the Skunk2 retainers, which are duty when you use their springs.
I am sorry to say, the S2 valve springs are kind of front loading springs: start hard, end soft. The heat treatment of high quality springs is quite time consuming and need a lot of experience and knowhow to get a spring which don't loose e.g. 10 % seat pressure during the break in procedure. If you know this lack of quality you specify the valve harder or define the installation height smaller, thence it starts with a specification of 60 [email protected] mm, installed you see likely 73 [email protected] mm and it comes out with around maybe 65 [email protected] mm. That's marketing related front loading. Problem solved? Not at all, the durability of the residual 65 lbs at installation height does much less decline, compared to break in phase, but it is still declining. Great quality springs from Eibach, PAC or PSI have a much lower break in loss and a lower gradient of loss during operation. I don't know the OE of the TODA valve springs, they most likely do not produce those themselves, but their quality is OE like. We've seen race engines running over 20,000 km on TODA cams and valves without any sign of wear. I saw 4Piston RR4 and RR3 cams which shows cam lobe wear before 10,000 km. That is a world of difference in part design, product fabrication quality and result.If you say it's the case I will make the swap!
