Building a turbo k20 1991 MR2 T-Top so selling all my parts I've been collecting for other builds to fund the project.
You can PM or Text me at 9366618ate9nine (if in the 48 states)
Sale terms:
All prices include shipping via UPS
Due to the condition of the parts and included shipping, all prices are FIRM
If you don't like my price, simply go somewhere else.
If a negotiated price is made, then the cheapest method to ship will be used.
All sales are final, no returns. Ask all questions before buying and if it's not in the picture, it's not included.
AFI original t4 divided twin scroll turbo manifold w/ 38mm wastegates Lightly used - $850
44mm Tial wastegate clamps and blockoff plates New - $100
Skunk2 billet oil cap, wouldn't take much to polish - $35
Wireworx S2000 Ap1 cluster install kit for EG chassis. Includes cluster, harness, k-tuned converter, and bezel - $700
http://wire-worx.com/cluster-conversion-harnesses/1227-wireworx-s2k-cluster-conversion-harness.html
APR original carbon fiber mirrors Mint for a dc2 integra but can be made to fit eg/ek - $175
EM Racing c-pillar brace (was mounted in a FA5 but not sure what car it really is made for but pretty sure it's for an eg6) - $125
J's Racing Rear Strut Bar for RSX - $250
J's Racing Monocoque brace for 8th gen Si (could be used as a trunk brace or where ever you wanted to mount it) BNIB - $200
Wedge Engineering Recaro bottom mount slider seat rails for 8th Gen Civic - $400
Corsport 06 Civic Si shifter cable bushings (can be made to fit 07+ by drilling I.D. out) - $30
Hybrid Racing Ground Kit BNIB - $40
Mishimoto K swap Radiator (identical to Griffin) includes 14" fan and fan mounting strips All Brand New, Never installed - $300
K-tuned Upper EG Radiator mount BNIB - $20
EG Hatchback Aluminum Drag Wing made by Godson Performance, mesures 16" and mounted onto oem spoiler. Yes, hatch is still usable. Will need one custom L-bracket for the lower support - $225
Skunk2 Pro-C coilovers (not the cheap pro-sII) BNIB - $900
ASP Battery Catch Can kit. Fits in stock battery location and fits Fullriver HC20, Interstate DCM0018, or Odyssey PC680 Batteries. Brand New Never Installed - $275
Spoon Yellow Powder Coated Valve cover with dual -an fitting to work with above catch can or other setups. Used and has the normal scratches. - $225
OEM Civic A/C delete kit (These are hard to come by) Does away with condensor and includes the engine bay plug as well as a few other parts - $125
K-tuned 3" pie cut turn down muffler BNIB (has small dent in the top of the exit which couldn't be seen once installed) - 160
K-tuned Clutch Line BNIB - 90
K-tuned Simple Fuel System setup w/ center mount gauge Brand New Never installed. -$375
NRG 49" harness bar - $200
Hybrid Racing Aluminum Black EG/DC adjustable mounts (Installed but never ran. Misplaced the mounting bolts. Passenger side bracket is brand new never installed since I had welded mine in. Anodizing has faded due to sun and bushings have turned a dark color from the original green) - $400
JDM PRC manifold with R-Crew plenum spacer
http://www.checkerdsports.com/rcrewproducts/rcrewpimp.html (installed but never ran) compares to rbc- $250
All-In Fab 2.5" short ram intake w/ velocity stack and screen. - $200
CC Twin Disc clutch (needs slight repair from flywheel bolt coming out) - $500
Hybrid Racing Shifter Cables that are almost new with bushing for 07+ civics (lost the 06 bushing). Could be used in a k swap vehicle using a k20z3 transmission and not have to change out the shifter mechanism, just use the k-tuned accord bolt-in billet shifter (
http://k-tuned.3dcartstores.com/TSX-Accord-Shifter_p_327.html) - $325
90mm Accufab throttle body w/ mustang bolt pattern (bushings are wore out and would need rebuilt or use for mock up) - $75
Hybrid Racing Short Shifter. - $250
3.5" Import DPS Rick Spec'd made into Intensity intake. Has Blox velocity stack/air filter, J35 coupler, and will provide hoses. Was a version 1 that required catchcan, but converted with hose barbs like version 2. Intake piping has a couple of scratches, but are hardly noticeable once installed. Relocation of battery is required, which is a simple D.I.Y. - $175
Tsudo Muffler that was on the slant axleback. Could be welded to any existing catback. Little scrape on the very bottom. - $80
K20z3 camshafts - $120
JRSC manifold adapter (Same as the Hasport) allows you to use snail style manifold on a k20z3, k24a2, and k24a4 head - $120
CP SC71473X Lightened 89mm 12.5:1 Pistons for k24/k20 Head (brand new)
http://www.ebay.com/itm/CP-SC71473X-...2bfcfb&vxp=mtr - $500
Pair of Works 18x6.5" inner barrels (used) - $200
Will add parts as I pull them out of my storage building and off of my wrecked k24 hatch...
