Yeah, this one. My Honda chassis knowledge is improvablethis car? i
Clarifies the super pursuit mode.245ish hp/165ftlbs and weights 2400lbs. (he has 45ish hp on me and is 300lbs lighter at this point in the race)
within our rules... he's hitting 141mph in the EM1 and i'm hitting 133.1 (for now) on the back straight... no draft.245ish on race gas is not bad with the 4.7 FD and short 4,5,6 ... makes sense. the back straight and front straight are the main passing spots there.
this same exact back straight, I was shotgun while Brady Wooddell was pulling 5th to 155mph and getting into 6th. to 162mph. In order to stop he has to do triple down shifts and my body would still experience room in the 5pt harness - full weight 01 DC2R w/ 200 lb passenger. 4.3FD JRSC K20a2. Mid-way on the back be passed a 911 GT3 Cup at 125mph. That "driver" and car were something else together...with the IPS SC cams & race gas, Hytech header (non-intercooled) 340ish and 210wtq 9,000rpm on a 86x86 with tar sticky R6 compound tires gets the F down on track. The DC2R has such a low front end it moves well on the top end with tar sticky tires and correct springs.
Car has been sold. chassis has 16,000 miles with the Kswap. The B18C5 is in a CRX with a JRSC kit.
I was sharing that story because it is amazing what Honda engines can do. VIR is a fun track, we are lucky to be close to it.within our rules... he's hitting 141mph in the EM1 and i'm hitting 133.1 (for now) on the back straight... no draft.
good call. opening it up is costly and timely. time is money, life is expensive...i'm hoping to limp through the next event and then pull the trans when i have 6 weeks to deal with it.
i just know its "not that bad" of a leak right now... i have no time to do this and do any suspension changes... AND at worst case i oil down the old ass clutch i was going to replace this winter anyway... so i just replace it early.good call. opening it up is costly and timely. time is money, life is expensive...
it really depends on what you want to do with it.... that drives your FD selection. for what i do, the higher the better until you hit your potential top speed.How do you like the gearing on the Z3 tranny? I am thinking of picking one up for $1200, which is a steal in this market. I wanted to try the 4.7FD.
I am really digging those custom tophats and the idea of caster adjustments. I want to start building splitters at some point and starting buying sheets of carbonfiber in 2'x2' and 3'x2' pieces. One side of the sheet is finished and the other is raw which saves some money. I mean there are kits out there already in the $800-$1,000 range for the DC5 and I am good on that. I have a few big expenses coming soon - new tires and set of dedicated track coilovers something of your caliber. I bought the BC Racing BR Extreme drop and am running a 2" drop for street. The DC5 only needs a 1.25"- 1.50" drop for track at most. So I figured I would save up and buy a race coilover for SCAA/NASA schooling and they would last the life of the car b/c I do not plan on doing actual racing like yourself.Ride height is set (raised it up 1/2-/34 of an inch)... new top hats are installed... cool suit switch is in... and the splitter is mostly finished (but i'm making a new blade next weekend)
The original top hats left some room in the strut tower and had wide spacing on the pinch bolt.
The new ones install much tighter to the strut tower.. and its is well thought out.
notice how the strut is clocked in the new top hats... that is a 30 degree clock (not 30* of caster) on the top hat, which is what Chris said he found to be optimal... and what the "new" top hats will be set to. The new hats wont be adjustable like these, but will be significantly cheaper because they will have much less machine work. See below:
that is 36 holes to adjust the struts orientation in the strut tower to get more caster.... 36x10 is 360... a 360* adjustment in 10 degree increments. Also note the 3 pinch bolt hole options that are spaced just enough to fit "max" camber in the car.
The cool suit just needs to get wired in and tested!
my buddy and fellow racer is pretty close to you... he has a cnc and all... he'll be making my sphericals... but i will need spare suspension parts to get them developed. i'll be in touch.I am really digging those custom tophats and the idea of caster adjustments. I want to start building splitters at some point and starting buying sheets of carbonfiber in 2'x2' and 3'x2' pieces. One side of the sheet is finished and the other is raw which saves some money. I mean there are kits out there already in the $800-$1,000 range for the DC5 and I am good on that. I have a few big expenses coming soon - new tires and set of dedicated track coilovers something of your caliber. I bought the BC Racing BR Extreme drop and am running a 2" drop for street. The DC5 only needs a 1.25"- 1.50" drop for track at most. So I figured I would save up and buy a race coilover for SCAA/NASA schooling and they would last the life of the car b/c I do not plan on doing actual racing like yourself.
Something else bro, my buddy has so many extra sets of oem suspension parts for your car and my car. I am going to pick for cheap front and rear parts just to insert spherical bearings into them for the track, so I can switch from a street bushing to race bushing. The suspension parts are dirt cheap. If you are interested for replacement parts for your car let me know, my guy in Yorktown, VA has you covered. He also has extra body panels for your car etc etc.
yeah let me know brother. It is like a pick and pull shop however those parts are normally laying around.my buddy and fellow racer is pretty close to you... he has a cnc and all... he'll be making my sphericals... but i will need spare suspension parts to get them developed. i'll be in touch.
