Thanks for sharing it. Awesome to see your car finally running on the track so well. How did you like the turn in into bends? Seems like your most of competitors can't follow your pace. I really enjoyed watching it. Great, I am happy for your first run!
WELL... most of the fast guys weren't there this weekend. there is a group of 4-6 fast guys and only 3 showed up. I generally finished between 5th and 7th. The fast guys are 1-2 seconds faster than I am/was at our tracks. BUT 7 of our guys (fast to mid pack) went to the national championship last year and placed 1st through 7th.
To have the car this fast out on its first race was a great sign. But it was still a hand full to drive. I'm basically right where i left off in the group. i was afraid that i would be behind learning the car... this isnt the case.
Braking: I was timid at first. new car, lots of tire walls, etc... BUT once i started getting used to them i could push them. and they work very well. this ABS system is amazing on track when you go a smidge too deep. Deleting this is a BAD idea and i completely see why people wreck these cars (and BRZs which have an amazing logic ABS system) when it randomly fails...
Entry: Initially I was very upset over the corner entry. It felt slow and wasnt rotating very well. In a FWD car you want the car to slide just a bit on entry to point the nose and then roll in the throttle from mid to exit, pulling the car out of the corner. My old car liked smooth everything... i found out that this car didnt like that... it like fast hands on entry (quickly move the steering wheel) and then smoothly maneuver the car through mid to exit.
Just adjusting to quicker hands on entry saved my front tires a lot more. My first two sessions I was over heating the front tires within 5-6 laps. switching my style i was able to save the tires for +18 laps on a much hotter day. This tells me I need to make adjustments to the rear of the car to get it to rotate. in the video you will see me shift just before entry at turn 7 to make the car rotate... you do what you have to do.
Mid: The front suspension is soft and the OSG diff is great... but none of this could put up with how fast the K20Z3 puts down the torque. In my old car with the B18C-R i could "usually" just mash the gas.... but you have to roll on the gas with this car... no big deal, the power curve is a monster. I need to get this car more on the curbing to help get the car pointed the right way... when i did it... it helped... on my optimal lap video, i'm on all the curbs. but i didnt really use them a lot because the car is new and the rear is super stiff.
Exit: It was pushy from the beginning so it will be this way on exit. we don't have the benefit of throttle oversteer (like rear wheel drive cars do), so you have to fix your suspension from the entry through the exit. that being said... front wheel drive cars enter slow and exit fast (see the bmws that pass me)... I overslow to let them by cleanly but i can still gain ground on them after i let them by.
my biggest issue... and its followed me to this car, because its a driver problem... I slow down 1-3 mph too much on the big corners at this track. the garmin data (which is amazing btw, and provided the video expediently) shows on the tablet that its worth 1.1-1.5 seconds a lap at this small course. the garmin showed that 1/2 a brake marker was worth .8 seconds at this track... so i know i can get that back immediately the next time i'm out.
altering just those two things (not the suspension) will net me enough speed to get to the front.
