Some people know... I've been racing a 2000 Civic Si (EM1) with a B18C5 (190hp/2500lbs) in the Honda Challenge H2 class. This was a well used chassis and a hand me down... finally the passenger side frame rail started to fail. The failure showed signs of failure by breaking passenger side axles ALL the time. This car is mostly parted out now... SO... it was time to move on.
A new chapter begins... apparently i have a coupe problem (CRX, Integra, bench seat F150, EM1, now this!)
We towed +2,300 miles down to Calhoun LA (from Northern Va) to get this beast. Its a 2007 Si coupe... OSG diff, Redshift Motorsports Double Adjustable coils, other suspension bits, Hybrid Intake, Skunk2 Alpha header, custom exhaust... hondata flash pro, spare trans, etc.
whats next? A trip to Piper Motorsports to get the custom cage installed... TL-S Brembos/Master, stainless brake lines, PCI seat bracket, all my old safety gear, my old 9 Lives wing, DIY splitter (i havent found one that is made commercially for the car), and 8 more RPF1s in 17x8 +45.... A2 oil pump conversion with a TracTuff baffle.
this car will be "built" for H2... 2725lbs, 200hp, and a 235/40/17 toyo RR
the "after" build picture:
UPDATE:
My VSA light is on because i removed the steering wheel angle sensor when installing the steering wheel setup. It is the green/white plastic that bolts to the turn signal stalk/back of the steering wheel. THIS IS A MISTAKE... DONT MAKE THIS MISTAKE! You want to keep this product if you intend to run ABS... or potentially VSA in the r*&n. There arent many 8th gen builds online for racing... no one says this. they are yellow plugs, i assumed they were air bag BS and removed it.
The ABS and VSA use it to modulate the systems. I have had to order a new one (yay $80 because i threw stuff away lol)...
UPDATE:
