im planning on getting 05 type s head and the tranny and putting it on 04 tsx block....would that work good in my 96ek hatch???
alright thanks a lotnikos said:You are going to run in some problems. It would be better to use the whole motor from TSX. The tsx head and the type S head are very similar.
The problems I am talking about is that on top of the TSX block there are some blocked EGR ports as well as the water line passage is positioned different than the k20a2 block or the k24a from the CRV.
If you were to use the tsx block and the Type S head, you will not be able to use the type S intake manifold. Unless you machine the block etc etc...
