i got a k20a3 in a ej1 "honda civic coupe 94" wat throddle and shifter cable do i use
o2seriousi · Registered Joined Sep 10, 2004 · 82 Posts Discussion Starter · #1 · Mar 20, 2005 Only show this user i got a k20a3 in a ej1 "honda civic coupe 94" wat throddle and shifter cable do i use
drhonda · Registered Joined Apr 14, 2004 · 14,747 Posts #2 · Mar 20, 2005 Only show this user you can use the shifter cables from any rsx. The throttle cable you might be able to use the stock one, try to see if it works.
