1 - 2 of 2 Posts
I have a 95 eg coupe with a k24/k20 swap. The car will crank but not start. I have determined it is the injectors not pulsing. I have spark and fuel pressure. All grounds are connected and even added a few extra. I have 12v at the injectors when the key is on. I have k20 harness with k20 crank sensor.
I have pulled the rail off and cranked with the injectors in free air and no fuel comes out. The immobilizer and multiplex are shut off in prb kpro. The car will pop off with starting fluid but not run due to no fuel. Any other options?
1 - 2 of 2 Posts
