hello all
i am currently in the process of trying to build a transmission for a k frank swap into my 2005 ep3. i originally intended on using a type s transmission, but when i purchased one about a year ago, my (then) ignorance did not tell me that it was an 04-05 transmission
. what i was wondering was whether i may be able to mix and match parts between the two transmissions i have? i would like to have the taller first gear my ep3 transmission has, the 2nd through 5th gears the 04-05 type s has, and a tsx 6th for fuel economy. i currently dont have the tsx parts--after reading about the difference in the tsb'd and non-tsb'd transmissions, i am unsure of what i need to get. what other parts would i need? any help would be appreciated
