immobilizer?
Thanks Nikos !! its appreciated , the dealer told me yes, i think what i will do is , before installing the k20a2 in, i will just plug the type-s ecu once at the dealer instead of sir ecu then i will be sure they gonna make it work , if they are not able i will buy the jdm ecu and wired up the fuel pump, where do we have the wired up the fuel , at the body? or please thanks again!nikos said:you can by pass with a kpro or jdm type r ecu. With a stock type s ecu, a honda dealer might be able to do it or you can get it reflashed. The basically need to match the key with your ecu.
Nikos
