41 - 56 of 56 Posts
Alright i checked for continuity and got about 0.4 ohms but when i checked continuity at the ECU pin(A7)i got around 2.7 something ohms but when i checked again it said (OL) WTF
.4 ohms should be good. When you measured at pin A7 what did you ground to? Was the ignition on and was the ecu plugged in?
OL means that there is infinite resistance or no continuity, basically no connection between the probes.
Discussion Starter · #44 ·
When i measured at A7 i grounded it somewhere around the shift cables next to the karcepts box.The ignition was off and the ECU was disconnected.
Super Moderator
2002 DC5 Type S
I have same issue freah k24 swap ran perfect until set launch control now i get p0335 and rev limited at 3k even after reloaded file from before changed it
Have you researched the " P0335 "code?
41 - 56 of 56 Posts
