buy non detergant 30w oil if ur gonna use engine oil..I also don't receive the Torco lube with it...
So should I buy lube or engine oil can do the job ??
Ok thank....
What will happen if I torqued it to 85 with moly lube...???
We realize too late my torque wrench was 10 lbs over calibrate... brand new Mastercraft :S
Ok thank....
Yes but 85 is fine.Too much torque is as bad as not enough with a aluminum block, head and a MLS gasket.
