1 - 9 of 9 Posts
Were is the right place to put this? the upper or lower hose? ive seen so many on the upper hose but herd that isnt the right place to put it.
Discussion Starter #5
Belongs in the lower because fan switch needs to be after coolant has been cooled by radiator.
Look in my sig for info on fan switch placement.
i bought a oem rsx radiator with the fan switch hooked up to it and should i put temp switch on the block or use the hose? and it would be fine if its on the upper hose?
on top as in the block on the upperhose on the adapter
block would be better, but upper hose works too. I had a bung welded into the top of my radiator and installed mine in the rad.
raldava said:
I didn't even use the hose adapter. I installed the temp sensor in the thermestate housing and since Im using Kpro, Kpro can operate the fan. It looks way cleaner this way. No cutting up hoses and no adapter. Read up on this thread below. Hope this info is useful
http://www.hondata.com/techk20swapfan.html
Here was my solution to this whole thing...
http://www.k20a.org/forum/showthread.php?t=34719
1 - 9 of 9 Posts
