1 - 5 of 5 Posts
Attached I have a picture, I was wondering if you guys knew what I am missing on the engine mount bracket as it's not flat and the bolt pattern is different. Engine is A K24A2.
Discussion Starter #2
Fairly certain this may be an issue with having to get a different mount but just wondering if anyone else has ran into this same problem? Google returns nothing.
Did you already put the crv post mount on there ? Or is that the tsx one ? You need a crv or afterMarket post mount for k24 swaps.
Also aftermarket companies make them out of aluminum if that's your thing. That mount is only good for the chassis it came out of.
1 - 5 of 5 Posts
