1 - 20 of 30 Posts
I am wondering if anyone have done this because I am about too. Are the rod journal the same in diameter on both motor?
My new simple oem build
k24a4
balanced, micropolished and chamfered crank
09 tsx 11.0:1 piston .25mm over
07 tsx rods
k20a oil pump, pan, oil cooler
k20z3 head / k20z1 cams
Rbc im
:confused:
Would I be able to rev this motor reliably to 8000rpm with this setup? I will post up pics of the build soon.
Yes.. With no problem...
throw some 06-07 TSX cams in there :up:
I though about that but the k20z1 has almost identical cams as the k20a so I was debating on whether I should spend that money. I think I would prefer to save up some money and buy the Ips Kme for a 250whp simple build later on.
It will fit in the block, but from the looks of it, you will experience Piston to Valve Contact. Check out the design of it.
Discussion Starter · #11 ·
Well I found out that I could not use the 09 Tsx piston and rings that I had bought. I will probably go with the 07 Tsx 10.5:1 pistons. It starting out pretty bad already. I should have done more research before ordering parts.
Sorry to hear that, what was the issue with them?
Do you have the pistons fitted to the block?
I would like to see a pic of them if you don't mind posting one up.
This is the older TSX piston compared to the new one.
You can clearly see that the design of the piston has changed a lot.
So... does the main problem lay in the rods? Are TSX rods longer than Accord A4 rods?
Discussion Starter · #18 ·
The 09 Tsx piston looks like the Accord K24a4 piston but instead of a dish it as a dome in the middle. The tsx piston has the same raise edge that the k24a4 piston has and that is the problem. It will hit the k20 head.
instead of using a 09 TSX piston, im pretty sure an alternative for higher compression you could shave the black deck height a couple thou, or machine the head, and use some high compression valves
1 - 20 of 30 Posts
