1 - 6 of 6 Posts
I heard Pierre Kleinubig (however you spell his f'd up name) is campaigning a race prepped TSX....and winning. Anyone found any details on this car? If its winning it has to be revving.
straight from realtime's website:
Acura TSX A-SPEC specs
Chassis
2550 lbs minimum weight (with driver)
Steel unibody with RTR prep and chromoly cage
RTR carbon-kevlar splitter with carbon/alum honeycomb undertray
RTR carbon rear wing
EFI data display dash
Hella switches and relays
Racetech Communications radios
Sparco seats and belts
Sparco steering wheel
RTR/Gemini center console
TOTAL Autobody paint work
Valley Graphix decals
Optima Battery
Suspension
Front double wishbone strut, rear five link with RTR spherical bearing inserts
Moton triple adjustable shocks
Eibach springs
RTR MOMBO™ rear anti-roll bar and mount
RTR front sway bar
RTR front upper arms
Brembo four-piston monoblock front calipers
Brembo two-piston rear calipers
Hawk Performance brake pads
SSR Competition wheels
Series-mandated Toyo Proxes T1-S rubber 234/40/17
Drivetrain
K24A2 block and head
12.5:1 compression pistons
RTR baffled oil pan
RTR cams
Mahle Pistons
Eibach valve springs
Carillo Rods
RTR spring retainers
EFI engine management
RTR header and exhaust
C&R Racing radiator
RTR carbon airbox
6 speed gearbox
Red Line Oil engine/trans lubricants
BOSCH spark plugs and fuel pumps
Goodridge hoses, lines and fittings
Tilton Flywheel and Clutch
Fuel Safe Fuel Cell
Yeah I kind of knew a simple search would have yielded those results but I was hoping for something a little more "inside". I know that this information isn't exactly advertised but I thought someone might have gotten the inside word somehow. That one badass Accord though I tell you that.
Jsut go to any of the world challenge races and see for yourself. Actually the last race of the season was a couple weeks ago at laguna seca so you missed out. I went to watch and support a friend's car running in the same race.
1 - 6 of 6 Posts
