1 - 20 of 38 Posts
Super Moderator
Oh boy.... Here goes another one... :eek:
Super Moderator
i already searched and found one thread on here but that was in 06
I dont think anything has changed since then.... :silly:
It's a good combo, but no K killer.. The K still emerges on top
Discussion Starter #5
lol tru say, but i just wanted to hear some experiences from you guys, if they keep up decent or just get pwned.
Super Moderator
It depends.. It may keep up with a stock Type S not properly tuned or just running poorly. But has no chance with a 2.4L setup or even some Type S or Type R Swaps..... Close, but no cigar.. Almost doesnt count.... That's the H2b motto...
Super Moderator
Discussion Starter #8
Thanks man, I just purchased a k20z1 and wanted to make sure I didnt end up spending extra money for the same type of setup. But I finally understand that the K series is far superior.
Super Moderator
No problem. You made the right move....
Super Moderator
Thanks...
My friend has an EK H2b and also has the balance shaft removal kit. He is out of town for the holidays, so i dont know if i'll get to race him. He took me for a quick ride 1-3rd....car was pretty quick. I really wanted to race him, car is nasty and he only has about 3k in his setup. Hopefully next week, if it happens there will be a vid up immediately:up:
Super Moderator
My H2B went 12.9 @ 106 in a 2200lb car on street tires (internally stock longblock with boltons)
Friends k20 swap went 13.0 in a 2200lbish car on street tires. (internally stock longblock with boltons)
My car went a best of 11.9 @114 with exact same setup , just on slicks.
K20 swaps I have seen are around the same.
I have seen K20 swaps with cams put down 225-235hp on a dyno jet.
A few of our stock bottom end H22s with just s2 pro 1 cams made 230.
Few local k20 swap cars with cams are running 11.60s- .70s
One of our h2b swapped cars with just cams is running 11.70s.
Keep in mind that the H22 is also a larger motor in terms of literage.
However the K definitely reacts much better to mods.
I'd say the h2b vs a k20 swap FROM PERSONAL EXPERIENCE WITH BOTH, are pretty much even.
However, throw in a k24 bottom end and the scale is heavily tilted in the K favor.
Now my built 2.6L ( 90x102) H motor, with big cams, $2000 billet crank, ported head, ITBs, etc made 318. Id say with a few other changes with some roller cams, it would make 330. MAYBE. . .
330 is a cake walk in a K24/20 and can be done with a stock crank and sleeves.
The k20 swap definitely gives the most room for improvement.
Some argue the cost will tilt those scales back towards the H2b . At first I believed that arguement, however some people have to realize to get my H to move the way it did, I spent 1100 on a transmission, 1100 on a header, spent countless hours on dyno just learning new things. You have to spend JUST AS MUCH money to make the H go fast as you would spend on the K.
Quality costs no matter what the valve cover looks like.
Any other questions , feel free to shoot them my way. . .
oh and this H2Ber is NOT going K . . . :p
1 - 20 of 38 Posts
