1 - 2 of 2 Posts
i have to rebuild my tranny second gear took a poop. My question is has any played around with using a different 1 and second gear for a better 60 foot time im running a 06 types tranny with a quiafe lsd
Take a look at the transmission chart in the transmission section to see what the ratios are like.. 1st and 2nd gear on any transmission has to be from the same shaft. It's molded as a part of the mainshaft itself. You can go from there and see what you think may be the best alternative for gearing AFTER those 2 gears.
1 - 2 of 2 Posts
