1 - 20 of 21 Posts
__________________________________________________________________________________________________________
Exhaust manifold Gaskets( H-B-k Series ) & O2 BUNGS
Your One Stop Shop for a replacement gaskets
ALL GASKETS 15 dollars each shipped for free to the lower 48 states
or 25 dollars for any combo
MILD STEEL O2 BUNGS 8 dollars shipped
STAINLESS STEEL O2 BUNGS 15 DOLLARS SHIPPED[/size]
AIM:HONDAPARTSALES​
BASIC INFO:
Gaskets:
o2 bungs:
MILD STEEL
Stainless steel
o2 fowlers / CEL (Check Engine light)fix:
stainless steel
Payment Info:
PM ME TO ORDER
OR
PAYPAL ME AT:[email protected]
CONFIRMED ADDRESS ONLY
DEALER INQUIRIES WELCOME!
EMAIL: [email protected]
AIM: HONDAPARTSALES
My question is in regards to the top three hole gasket? Can you get this in an ID 70mm? A friend of mine bought a Skunk2 70mm exhaust for his 07 Si Sedan and the guy didn't ship the gaskets. He needs a three bolt gasket and a two bolt gasket. Let me know man, thanks.
the 3 bolt one i have is a 2.5 inch .
70 mm =2.755905511814 inches
it will work still but you might need to grind off some of the inside.
unless the outer measurement is 70 mm and then it would work perfectly
Discussion Starter · #7 ·
now offering
After much thought and many requests for the once popular RMF Narrow 4-1 Header, i finally tracked someone down that was having them made. With RMF no longer in business and the Narrow headers getting harder and harder to find, there was a place in the market for these exhaust manifolds. These headers were replicated off of the original RMF NArrow 4-1 Header. I was sent the replica header to test. The following Dyno Charts are the results of that testing. I also have sent some samples around to other shops that should be posting their results as well in the next few days.
SPECIAL HT PRICING, I WILL PERSONALLY WARRANTY ALL HEADERS.
HEADERS ARE IN STOCK AND NOW SHIPPING GET YOURS TODAY!
RMF NARROW STYLE 4-1 Replica Header now available.
-304 Stainless Brushed Steel
-2.5 in collector
-Hand Tig Welded
-1 Year Warranty against breaking/cracking backed by me
-FITS ALL B SERIES: b16,B17,B18, GSR, ITR, LSVTEC
-FITS ALL CHASSIS: EG, EK, DC2, DA and EF
-EF and DA require modding of Front Crossmember
-Slight trimming of standard OEM Size Rad fan required (1/2) notch
-CLEARS AC AND POWER STEERING
DYNO CHARTS
1.8 LSVTEC with Tri-y header versus RMF replica
RED RMF Replica
Blue TRI-Y HEader
Stock GSR with intake, ebay 4-1 header, exhaust
RED RMF Replica
BLUE Ebay Header
GROUND CLEARANCE
HOLIDAY SPECIAL PM ME FOR PRICE OR EMAIL, TOO LOW TO POST[/B]
bummpppppppp
1 - 20 of 21 Posts
