98 gsr head- skunk2 springs and retainers, skunk2 stage 3 cams, skunk2 cam gears, titanium valves, mild port and polish, skunk2 fuel rail, rc 310cc injectors, skunk2 intake manifold,hondata intake gasket, gsr throttle body, mishimoto carbon fiber intake, gsr distributor, alternator.
98 ls b18b1 block- nippon head gasket, 83mm 13:1 je pistons, eagle rods, balanced crank, kms block girdle, arp head studs, 4-1 header, megan high flow cat.
gsr trans, clutchmasters stage 1 clutch, type r flywheel. type r oil pump, new water pump, timing belt, oil pan. gsr axles, chipped p28 (yosolo tuned), gsr shift linkage, skunk2 short throw shifter, skunk2 shift knob, ek hasport motor mounts. less than 27k on motor. 100% legit, receipts for everything. asking $4500 or trade for a k20 type s wit trans or k24 tsx long block wit trans. pix are the same motor jus different valve cover... located in new jersey
