1 - 20 of 30 Posts
hey..im selling my fully built k24 longblock...motor made 292hp with 202tq....went 10.8 in my bubble this summer...
vin: shsrd78844u257466
block id: 3567444
Motor : maybe 3 miles at most on it...
K24a1 block built by fischer auto machine
88mm 13.7:1 wiseco pistons
Blueprint Pro series Lightweight I-beam rods
Factory 99mm crank micropolished and fully balanced
Golden eagle headstuds
Golden eagle 88mm laser cut OEM headgasket
All new factory main and rod bearing along with a new rear main seal
Brand new Type-s oil pump and baffle
Brand new timing chain, guides, and tensioner
type s starter
karcepts ep3 idler pulley eliminator kit with type s alternator
Head:
TSX Tommy head
Fully ported by Tommy G. from TG heads with 3 angle valve job
Skunk 2 stage 3 cams
Supertech valvesprings
Supertech Titanium retainers
Supertech valvespring seats
Supertech valve seals
Manley stainless steal valves
Manley valve locks
$3500
732-570-4201...only call if you have $3500 cash and want to buy it..thankyou!
HONDA HEAVEN RIP
bump, what are you duin man gettin outta it?
because i came across a good deal on a skyline r32 and bought it...done with hondas for good...motor is very legit and have many high class vouchers for it...lmk
I have an 04 rsx, do you know if there are any other components needed to run this besides Kpro?
Also, I know a lot of people do the k24 block / k20 head, just curious why you didnt go that route?
I have money in hand for this if I decide to go this route, but would like to see some pics first
Discussion Starter #16
the type s head and tsx to me run the same once ported the rite way...in my opinion i like the tsx head better because of the fact that the newer one's come with oversized intake valves...i have pics available but need your email address...and yes you will need a kpro and yes this is a direct bolt up for an rsx...
what kind of gas did u run with such a high compression (13.7:1) ?
i used vp q16...yosolo has tuned many of the same setups on 93 pump and they still run strong to this day...in fact one of the guys i know built his motor almost 2 years ago and daily drives it to this day with the same setup on 93 pump...
How much did your car weigh when you ran a 10.8?
Who tuned your car?
my car weighed in at 1976 with me in it with a 6pt cage...car hooked a 1.55 all 3 passes...and yosolo tuned the car...personally i think he's the best k-series tuner out their...
Bump! I can vouche for this guy he's a good seller bought
a clucth line from him and recieved it. Good communitcation
and sent tracking number
1 - 20 of 30 Posts
