1 - 20 of 60 Posts
fullrace, bdl and k-tuned
skunk2 stage 2 version 3 cams forsale as well, pm and ill get pics up asap
Purchased this manifold from eddsi, he can vouch for it. I never used it(changing my setup). Its a twin scroll dual 44mm wastegate manifold. Has a flange added for the new precision Turbo(to clear the cam sensors). No boost creep with this set up! I can cut the flange off if you don't want it. $900
The k-tuned block off plate is bnib. Selling this cuz I'm changing the intake setup too. This plate can be used as a block off or rotate the iacv sensor for better fitment and a clean look. $40
Blackworks radiator Brand NEW! im changing my Intake manifold and intercooler set up and this will be in the way so i dont need it!
also have the factory radiator outta my rsx that i no longer need.
70mm BDL Tb, this was used for 6 dyno pulls and not even a mile on it. changed my intake setup so i no longer need this.
ive got a k20a2 oil pump and chain, also a k20a3 oil pump, and a timing chain cover.
oem rsx powersteering rack with all lines, reservoir and pump.(will not include tie rod ends)
3 oem rsx mounts, all but the front.
1 - 20 of 60 Posts
