Hey k20a, it's been a minute
as I continue to prepare for my k24 turbo build, there are a number of things I want to do in advance; one of these things is the fuel system.
I already have a rail with AN fittings, and what I would like to go ahead and install are the lines, FPR, and fuel filter if its necessary (Is it, or will the stock one suffice?).
My question is, can the parts listed above be installed on the stock ECU without affecting drivability? I assume they can be assuming the FPR is adjusted correctly, but I just want to be sure that it wont cause the car to run super rich or lean. If it does, I won't have the necessary software to correct this
Note that I'm NOT going to install the injectors or pump yet, just the surrounding bits, so no extra fuel will actually be flowing. honestly, I think I just answered my own question, but I need to be 100% sure
