1 - 6 of 6 Posts
When we should upgrade the fuel pump...
this is my setup...
RSX-S fuel pump
RSX-S fuel press regulator
RDX K23a 410cc injectors
K20a2 cylinder head
K20a camshaft
K20a PRC intake manifold
K20a2 throtle body
K24a1 engine block
I expect get something aroud 220 - 230 whp in a range of 8000rpm
Should I change my fuel pump before planning on a dyno
When we should change it.... how many hp the OEM one can handle ??
Based off the current set up, I would say your stock Type S fuel pump should be able to handle it with out any issues.
-Robby
i may be gonna change de camshaft in 2010 for something like IPS k2 or Blueprint S3
do you think I'll need to change the fuel pump after this upgrade ???
IMAKEBOOSTATIDLE
yeah palmerblock (tuner at churches) said that a stock fuel pump will handle over 300whp
ok thank you :up:
1 - 6 of 6 Posts
