1 - 4 of 4 Posts
I have a k24a4 block/k20a2 head frank w/ type r tranny and ecu. Right now the type s injector are in. It feels like it really bogs down until 3 grand then it really starts taken off. Kinda like you're feeling 3 VTECs. So I was thinking too rich or too lean. I pulled the plugs today and they looked really good. So now I'm thinking too lean, right? But I'm all ready running like 51/52 psi. Should I bump the pressure up (if so how much) or should I get larger injectors (if so how big, brand, etc...)?
PS- no code in ecu except p0600a (Serial link Comm. malfunction) (been told it doesn't affect preformance)
Discussion Starter · #2 ·
any suggestions?
If it's pulling hard through your peak torque rpm range then bigger injectors certainly aren't the problem. Timing usually tends to be the cause of low rpm sluggishness with a sudden surge coming on at the upper rpms. That's where I would be looking.
1 - 4 of 4 Posts
