1 - 20 of 40 Posts
Discussion Starter #6
I 'm not sure, i need to call either Wilwood or Fastbrakes to ask.
K24 USDM EG
if i can fit my 16" over them ill pick them up. if you could find out that would be great. my buddie has the same set up let me try wheels on his tonight. if they fit ill let you know.
Discussion Starter #10
someone on a local board is gonna find out if they fit as well.
Discussion Starter #13
fastbrakes told me they fit 16". Its still up to the purchaser to make sure of it.
The easy way to find out is to take the caliper and stick it on the rotor... then measure the didtance. I had to mockup like this to get mine to fit when I had my GSR (the wheels that were supposed to fit didn't). What is needed is a hi visc wheel... ie a wheel that will clear BBKs. Sometimes the wheel rim part will curve down by the spokes and hit. When in doubt call the wheel manufacturer and ask them.
Nice deal on the BBK and you WILL stop on a dime! Don't forget to watch your rearview mirror after installing as the person behind you might not stop as fast.
1 - 20 of 40 Posts
