1 - 8 of 8 Posts
I have USED 88mm K24 X-Forged CP pistons w/1,200 miles. RODS arent included in this deal.......SOLD!!!!!!!!!!!!
Reason for Price Being So Low:
Need New Piston Rings are $100 from CP
Due to motor heating up pistons shrunk a little took them to the machine shop to have them checked out and was told the pistons are still good and can be re used again. The only thing in order for them to be re-used each piston has to be bored and honed to each cylinder.
Pics:
Please Bump My Thread If You View Thanks.....
only problem is if the pistons changed size then you need special rings to fit each piston. Am i not mistaken
To be honest i believe the machine guy told me i would have to call CP with the part # of the pistons and order the rings and then take it to the machine shop and bore each piston to each cylinder and label it...But I will double check that in the AM just to make shore if that was correct.
let me know for sure.. it still just seems risky but for the right price i may take them off your hands..
Yeah i spoke to the machine shop he said get the rings for the 88mm bore....he said the top of the pistons is good to go..he said its the bottom where most pistons tend to shrink is what shrunk a little
1 - 8 of 8 Posts
