Hello Everyone,
Here we have a couple of K24 crank position sensors and plugs that have been modded to work on a K20a2 engine harness. I left a lot of slack on the wiring to make it easy for those who want to solder them up to their existing k20a2 wiring harness.
I also have a bunch of other Oem K parts. If there's something you need, pm me and we can go from there. I can add plugs/wiring to any of the sensors listed below.
Will ship anywhere. Located in Illinois (60181) USA.
Here's a general list:
1. Two k24 crank position sensors w/ plug (modded)-- $25 each
2. Intake Temp Sensor -- $20
3. Map sensor -- $15
4. Oil sending units-- $10 each
5. OEM transmission detent springs-- $5 each
6. OEM transmission shifter springs-- $15 for both (includes new o-ring)
7. Crankshaft pulley key-- $5 or free if you spend more than $10 with me
8. Flywheel inspection cover-- $20
9. Crank main seals (front/rear) -- $5 each
10. Drain plug bolt/washer -- $5
11. K20 timing chain guides-- $20
12. K20 timing chain tensioner-- $20
13. Oil squirters-- $5 each
14. Clutch pressure plate bolts-- $15 for all 6
15. Z3 pistons/rods-- $20 each
16. Z3 fuel lines-- $20
17. Z3 clutch lines-- $20
18. K24a2 Intake manifold cover-- $30
