1 - 9 of 9 Posts
K24A4 Block & Crank w/ less than 21,000 miles total.
This was purchased used w/ less than 20,000 miles on the clock, torn down, and built. Some of you may know the story of my engine failure and some may not so I will summarize... I built the motor and did not check clearances (trusted someone) and ate a valve. Shit-canned the head, number one or four piston and rod and lightly scuffed the bore w/ less than 1,000 miles on the set-up.
Was going to rebuild it and replace my K20A2 but have had no interest since the KraftWerks SC Kit fell into my lap.
Taking Offers... Crank has been re-polished and block has been honed. The scratch is still there but it is low in the barrel and may not affect anything. If you like to do things right... bore it .25" over and your golden!!
I also have a NEW set of TSX rods and pistons that would be at home in this combo if you chose to run it as is. $350 shipped
Rob~
Discussion Starter #4
Justa heads up... I have an offer on the table. The block and crank may sell for $450. Not rushing you just letting you know
1 - 9 of 9 Posts
