1 - 20 of 100 Posts
well as the title says, im more or less selling my whole setup... its a full k24a2 block.
made 414whp and 300wtq on 10 lbs creeping to 12. the ignition timing was not touched due to time constraints on the dyno. motor has less than 150 miles, the tranny i got off of CJM works awesome, i put less than 150 miles on that as well.
the motor,
block: bottom end was assembeled by spoolin performance/redzone out of freemont, ca.
ib spec h-beam rods
cp, 9.0 pistons
arp headstuds
oem head gasket.
type s oil pump.
top end,
hytech valvesprings and ti retainers
brian crower stage 2 turbo cams
rbc intake manifold and type s throttle body
thermal gasket
the turbo kit...
its a one off topmount by redzone/spoolin performance.
garret t4/t67 journal bearing turbo.
big front mount
tial bov and waste gate
precision 1000cc injectors
bdl fuel rail
the trans
stock type s bought from CJM and i put it thourgh no abuse.
clutch is a clutch masters stage 5
mounts are hasport and axles are drive shaft shop 2.9
wiring harness is a type-s modded with an fjo injector driver
hybrid conversion harness
hondata kpro. will have the tune on it. tuned by jon kerr
hybrid clutch line and upper rad insert
no name aluminum radiator
karcepts rad and shifter plate (modded to fit a del sol)
type s shifter box with a modded b&m short shifter (does not kink shift cables)
will also include the downpipe. this is a complete swap, buy a flywheel and your good to go, nothing else needed....
the bad, you will need to buy a flywheel
asking 8,000. this is the cost of a n/a stock motor swap. buy it all here and now and be running by next week.
im not going to part this out unless it does not sell, i have many k20a3 parts as well as various other parts, just ask ill see if i have it.
Re: t/w k24 built, turbo kit.. complete swap
spoolin performance, and i did the pipe from the throttle body to intercooler
ttt... come on guys, im selling to help start a new project...
Super Moderator
Would you part the engine and turbo kit? This may help you get a buyer faster....
Is the delsol for sale after the motor is taken out? Bump cause a setup like that is one of my top 5 dream vehicular toys, Turbo K-sol !
Discussion Starter · #9 ·
maybe, well possibly. if i can get 2 people at the same time then i have no problem.
the del sol will not be forsale after this swap is gone... im going another route with it all together, that only the jalals know about :D :D
Infinite levels to this..
bump for a very nice setup and a future beast!!!:up::up::up:
Discussion Starter · #15 ·
er, it was only on 10lbs, reason being is that i have a stock mapsensor, otherwise im sure it would be at the 500whp mark on pump.
Discussion Starter · #16 ·
bump cause it is all removed, ready to be shipped out.
1 - 20 of 100 Posts
