Located in Southern NJ
First Gen Rcrew header and 3" Thermal Exhaust: EG hatchback specific. Header is finished with high temp coating. Muffler canister is painted flat black. Custom 3" v-band connector setup / flex pipe welded in. Will not part them unless i have people to buy both...- $900
Holeshot Racing EG Swap Axles: Brand New. Never Used.- $275 shipped o/b/o
_______________________________________________________________________________________________
2002 K20A2 Long Block: 14k miles. Swap was purchased in 03 from a rear wrecked Type-S. Legit with paperwork. VIN# disclosed to serious buyers only. May be willing to part head and shortblock if there is enough interest. Comes with all sensors and coolant pipes/hoses. Valve cover is not included.-SOLD.
Type-S Half/Mid Shaft: Bought new from Acura. Used 4k miles. Mounting hardware included.- SOLD
Clutchmasters K-series Stage 4 Clutch: 4 puck disc. Brand new in box.- SOLD
K20a2 Flywheel: Will need to be resurfaced.- SOLD
MT Flywheel Bolts: Need these if you bought a swap with an automatic transmission- SOLD
Golden Eagle First Gen Fuel Rail: Gloss black with fittings- SOLD
Stock Type-S Injectors: 14k miles. Great condition.- SOLD
K20A2 Starter: 14k miles. Great condition. Mounting hardware included.- SOLD
K20A2 Alternator: 14k miles. Great condition. Mounting hardware included.- SOLD
2002 K20a2 Transmission: 14k miles. NO GRINDS. All brackets have been powder coated gloss black.- SOLD
06+ SI LSD with Bearings: Under 15k miles, perfect working condition. All you need is a speedo gear to work with an 02-04 VSS transmission.- SOLD
Hondata K-pro PRB ECU: Serial#610. Jeff Evans tuned .kal for this setup included: http://www.k20a.org/forum/showpost.php?p=111202&postcount=1- SOLD
K20A2 Throttle Body: All sensors included, and in working order. Cable bracket has been powder coated gloss black- SOLD
RBC Intake Manifold: Shaved, plugged, and coated.- SOLD
First Gen Karcepts RBC Adapter: All hardware and gaskets needed for install included. The original one with no writing on it. You know, before everybody started making knockoffs of it...- SOLD
Primary 02 Sensor: Used 4k miles- SOLD
First Gen Hasport EGK-1 Mounts: Used. Complete with all hardware and install manual.- SOLD
OEM Combo EG Swap Axle Setup: Used. Held up to 230hp just fine.- SOLD
Type-S Coil Packs: 14k miles. Great condition.- SOLD
