No, It won't affect it at all. The plastic arm doesn't come in contact unless you set it in the position to lock out 5th and try throwing 5th. No damage would occur unless you drop kick your gear into 5th in the locked position...loldid you use this with oem plastic shift arm? will it affect/wear out the plastic shift arm if used with it?
