**If the price is right or if you have what I want in a trade is the only way I'll let it go, no low ballers, and I don't want your D-Series Civic or bolt-on LS Integra.**
Other vouches can be seen from my username K-20Power on ClubRSX.
Trades I'd be looking for are a turbo B-Series or H22 EG/DC or an S2K(AP1 or AP2)
Other offers may be considered.
Now on to the car. *NOTE*: If you don't like it, or any of the parts or what I did with the car keep it to yourself.
Price: $12,500 OBO
1992 Honda Civic LX 4 door.
-CLEAN title
-Shell is clean, underneath the car is spotless (surprising for a NY car right?)
-Paint is fresh as of September 2007
Motor:
-2005 K20z1
-19,568 original miles, ~1,500 on fresh motor (will change because the car is my daily driver)
-Freshly built motor as of this winter
-86.5mm Wiseco 11.7:1 pistons
-Eagle rods
-ACL Race bearings
-New OEM oil pump
-Head was freshly re-built with Blueprint valvetrain
-Blueprint Stage 2 cams
-Supertech flat-faced valves w/ the 02-04 valve keepers
-Supertech valve seats
-RBC intake manifold
-RC 550cc injectors
-Golden Eagle fuel rail
-Steel braided fuel lines
-Walbro 255lph
-Aeromotive fuel pressure regulator
-Hasport mounts
-Karcepts shifter mount
-BDL 70mm throttle body w/ Karcepts 70mm TB adapter
-Batlground swap header (Hytech replica)
-Hondata intake manifold gasket
-Hondata K-Pro w/ 05-06 adapting harness
-K-Tuned K swap CAI
-OEM ITR valve cover
-OEM '06+ Civic Si black coil cover
-EP3 idler pulley to remove powersteering
-NGK BKR7e spark plugs
-2.5" Kteller exhaust w/ 18" Magnaflow resonator & Magnaflow muffler (sounds awesome!)
I always change the oil every 4k-5k miles. I have only used Royal Purple 5w-30 since I put the swap in at 4,983 miles. Have only used the OEM blue Honda oil filters.
Transmission:
-Just recently went through it this winter, gears and everything looked immaculate
-No "false" 3rd gear which is said to be common on the 05-06 6 speeds
-Have only ever used Acura's newest MT fluid, changed every 4k-5k miles with the engine oil
-OEM DC5-r LSD
-Competition Stage 4 6 puck ceramic clutch (sprung)
-Fresh resurfaced OEM flywheel
-Driveshaft Shop 2.9 axles
Suspension, Stoppers, & Wheels/Tires:
-Has brand new Function Form Type-One coilovers
-Front & rear camber kit
-Blox rear lower control arms
-New rotors and pads in the front, rear drums were replaced about 5k-6k miles ago
-15x6.5 Bronze Rota Grids w/ General Exclaim UHP 205/50/15's
Exterior:
-OEM Frost white
-6000k HIDs
-New OEM black door trim
-New OEM Honda badges
-OEM rear spoiler
-"Type-R" replica front lip
-Lightly smoked OEM taillights
Interior:
-Interior color is tan
-Has '06+ Si front seats w/ matching black seatbelts
-'05 RSX-S gauge cluster fully functional
-Sparco Flash 5 steering wheel w/ polished/chrome center
-Sparco quick release hub
-Skunk2 6 speed weighted shift knob
-Autometer Temp. gauge
-Autometer Oil Pressure gauge
-NGK AFX Air/Fuel wideband monitor
-JVC deck
-OEM Honda foglight switch
-The car also has the Acura keyswitch with the imobilizer along with the 3 keys that originally came with the RSX-S when I got it.
The car was tuned at Synapse Motorsport in Scotia, NY. The car made 222whp/164wtq. The Blueprint cams provide a very nice powerband, the midrange power is awesome. The car is an absolute blast to drive. I also did a small wire tuck to clean up the bay a little bit, the bay was also painted this winter with a single stage paint. Looks flawless and shines like no other.
And here are some pictures: *Will provide more upon request for serious inquiries*
Pictures of the car from last year:
(no longer have the Sparco harnesses)
Thanks for looking guys! Bump if you look please!:up:
Price: $12,500 OBO
-CLEAN title
Motor:
-2005 K20z1
-Eagle rods
-ACL Race bearings
-New OEM oil pump
-RC 550cc injectors
-Walbro 255lph
-Hasport mounts
-K-Tuned K swap CAI
Transmission:
-OEM DC5-r LSD
Exterior:
-OEM Frost white
-6000k HIDs
-OEM rear spoiler
Interior:
-JVC deck
