1 - 20 of 30 Posts
I have lowered the prices one last time. Crack Head Prices only good for the next three days... then everything gets deleted because I wont have access to these items again until Late July.
I can be contacted via:
Phone = 562-477-9257
Email = [email protected]
AIM = eK24monster
Paypal addy = [email protected]
Prices DO NOT INCLUDE SHIPPING
USED 96-00 Civic HB 16.5" Test-Pipe w/ Cat Cover Welded On $20 (No Picture) REDUCED 4/27
USED but not used... Civic Space Saver Spare Tire $15 (No Picture) REDUCED 4/27
NEW Geniune Honda Accessory Belt $5 (Pt# 4PK845) (No Picture) REDUCED 4/27
NEW Geniune Honda Accessory Belt $5 (Pt# 4PK1065) (No Picture) REDUCED 4/27
NEW Geniune Honda Accessory Belt $5 (Pt# 6PK1015) (No Picture) REDUCED 4/27
NEW Turbonetics Evolution Wastegate $130 REDUCED 4/27
USED Tube & Fin Inter-cooler $60 REDUCED 4/27 (Core is 23" x 6.5" x 3.0") 31" long from inlet to outlet. 2.5" inlet and outlet
USED K Series Starter $65 REDUCED 4/27
VERY LIGHTLY USED Earl's Oil Cooler Kit $400 REDUCED 4/27 (Includes a 13 Row "Extra-Wide" Temp-A-Cure Oil Cooler, Billet Oil Filter By-Pass (Not Pictured) Adapter, Billet Remote Oil Filter Mount, Billet One-Way Check Valve, -8 Ano-Tuff Fittings, and -8 Pro-Lite 350 Hose) Was designed and used on a K Series but can be configured for a number of Honda engines. Uses HP-1/ HP-3 or equivalent Oil Filter.
NEW AEM 30psi Pressure Transducer (MAP Sensor) w/out plug $60
NEW RDX Fuel Injector $25
NEW Wheel Studs (12mm x 1.50) $45
USED Nakamichi CD-45z Receiver/ CD Player $60
USED Genuine Honda K Series Belt Tensioner $15 REDUCED 4/27
USED Genuine Honda 1996-00 Civic Dimmer Switch $5 (Light Gray) REDUCED 4/27
USED Genuine Honda 1996-00 Civic Power Mirror Switch $10 (Dark Gray) REDUCED 4/27
USED Genuine Honda 1996-00 Civic Sun-Roof Switch $5 (Light Gray) REDUCED 4/27
USED Genuine Honda 1996-00 Civic Combo-Switch $10 REDUCED 4/27
USED Genuine Honda 1996-00 Civic Cable Reel $10 REDUCED 4/27
USED Genuine Honda 1996-00 Civic EX Brake Master Cylinder $20 REDUCED 4/27
USED Genuine Honda 1996-00 Civic EX Brake Prop Valve $$10 REDUCED 4/27
NEW Fluidyne Radiator Cap $5 REDUCED 4/27
NEW AEM B Series Fuel Rails (25-100R) $65 ea. REDUCED 4/27 One (1) Red Left
NEW AEM Power Pulley Set (no belts) for H22. May fit other applications... I know that AEM only had two P/S Pulleys for all the Honda apps they offered so there is some crossover. $30 REDUCED 4/27 (you can keep the P/S pump)
USED Genuine Honda H22 Coil $10 REDUCED 4/27
USED Genuine Honda H22 Starter $20 REDUCED 4/27
USED Genuine Honda 1996-98 Civic HB Tail-lights. Small chip in the driver-side lens. $60 pr. REDUCED 4/27
NEW Genuine Honda 1996-98 Civic HB Tail-light Gaskets $10 pr. REDUCED 4/27
NEW RBB (TSX) Rods $190 REDUCED 4/27
NEW 87mm TSX Pistons w/ Rings and Wrist Pins $220 REDUCED 4/27
K Series (PRB) Intake Manifold $45 REDUCED 4/27
shift knob came today, thank you robert. Up for an awesome seller:up: Ive bought a few things from him now, stand up guy here people:up:
Discussion Starter #19
I do.
I have a set of 87.5mm 11.1:1 Wiseco's that I was going to use in my Supercharged K24 Build but now that I have lost my job... I'm trying to unload the easy to come by stuff.
I have till tomorrow to sell them... if I wait any longer I miss the opportunity to send them back to Wiseco for a full refund.
I'll let those go for $350 + Shipping.
I also have these...
NEW Std. Bore (87mm) TSX Pistons w/ Wrist Pins and Rings. I did not want to post the Wiseco's and the RBB's at the same time... to much piston to look at and may limit my sale on one or the other. If you want these, let me know.
I should be back in town in time for Eibach... maybe even a week or so sooner. I'm gonna try to use that event to network and rub shoulders w/ some industry people.
1 - 20 of 30 Posts
