1 - 7 of 7 Posts
Discussion Starter · #7 ·
what are the specs on the manifold? i have an offer but its a bit of a lowball lol
the specs are no different than the big throttle body opening that AFI offers with the 90mm bore, the only difference here is the bolt pattern is setup for a b-series 74mm throttle body which is an option that AFI offers (and i also happen to have a 74mm RPM throttle body for b-series whcih made 280whp on my old all motor b-series stroker motor). Alternatively you can also have a machinist bore the opening to 90mm or bigger as well, and use a Edelbrock adapter plate for b-series to Ford and then use a Ford style 90mm throttle body...so no need to lowball, and i'm negotiable.
1 - 7 of 7 Posts
