1 - 1 of 1 Posts
SOLD FS: 500Whp Turbo k20a2 EM2 2002 Honda Civic $7500.00 obo
SOLD
2004 Acura RSX 6spd K20a2 swap (with power steering)
PortFlow Port & Polish
Supertech Stainless Steel nitride coated valves
Dual Valve Springs
Titanium retainers
Competition 3 angle valve job
Resurfaced Deck
Blueprinted bottom end with Spec Sheet
ERL Polished Crank
ARP Main Stud Kit
Eagle Rods 3/8” Rod Bolt
CP Pistons (9.0:1)
ACL Main/Rod Bearings and Thrust Washers
Hondata KPRO (With 4 bar map sensor, Boost solenoid, etc…)
HaSport motor mounts
’02 - ‘04 RSX K-Frame
Custom Full Race T3 Turbo Manifold
Full Race K Series Vertical Flow Intercooler
Koyo 36mm Radiator
Tial Q 50mm Blow Off Valve – 8psi Spring Black
Precision Turbo & Engine 6262SP
Precision Turbo & Engine 46mm Wastegate
DEI Exhaust/Fire Wrap & DEI Turbo Shield
Oil Return line 10an ProSeries Black
Custom return style fuel system
Walbro Fuel Pump 255LPH HP
Aeromotive A1000 Injected Bypass Fuel Pressure Regulator
Injector Dynamics 1000cc injectors
Greddy 60mm PH oil Press White
Greddy 60mm PH Boost Gauge White
Greddy EXH Temp Gauge
AEM UEGO Wideband Controller
Skunk2 Racing Pro Series “PRO C” Coilovers
Custom AV Tuning 3” Exhaust
Competition Clutch Stage 4 – Strip Series 1620 Clutch Kit
Lightweight Flywheel
Quaife ATB Differential
Skunk2 Racing Composite High-Volume Fuel Rail
Custom Battery Relocation to behind passenger side bumper
Multiple Custom Support Mounts/Brackets for various parts
Has power steering. No A/C. Car runs great. Paint is starting to come off front fender and trunk.
Car is located in Houston Texas.
1 - 1 of 1 Posts
