1 - 3 of 3 Posts
Located in Bay Area, CA
Prices:
> B18C1 Complete Swap Rebuilt with 9,000 miles (88-91 Honda Civic/CRX) - $3000.00
* JE 10:5:1 Pistons w/ Rings (81mm)
* ACL Standard Main/Rod/Thrust Washer Bearings
* Balanced Entire Bottom-End Assembly
* Decked Block (.003")
* OEM ITR Oil Pump
* OEM ITR Water Pump
* OEM ITR Timing Belt
* OEM ITR Rear Main Seal
* OEM ITR Oil Pan Gasket
* OEM B18C1 Oil Pan
* OEM B18C1 Connecting Rods
* Micro-polished B18C1 Crankshaft (balanced)
* Stock GSR B18C1 Cylinder Head (resurfaced .010")
* OEM Valve Seals
* 3-Angle Valve Job
* Skunk2 Tuner Series Stage 1 Camshafts
* OEM Cam Gears (Skunk2's in picture NOT INCLUDED)
* Blox Racing Intake Manifold (cut open, port-matched & ported/polished)
* Professional Products 68mm Throttle Body
* P2R Intake Manifold Heatshield Gasket
* P2R Fuel Rail
* NRG Innovations Liquid-Filled Fuel Pressure Gauge
* NRG Innovations Adjustable FPR
* 440cc Saturated RC Fuel Injectors (high-impedance)
* 3" Custom Cold Air Intake w/ Fujita V-Stack Air Filter
* RMF Replica 4-1 Header (2.5" collector)
* Innovative Billet Engine Mounts (60A street urethane stiffness)
* GSR Transmission (100% flawless; no grinds, no pop-outs, no bearing noise)
* Action Clutch 1MS 6-Puck Sprung Disc Clutch Kit
* GSR Resurfaced Flywheel
* Axles
* B-series EF Shift Linkage (adjustable by HCP Engineering)
* Polished Aluminum 92-95 Dual-Core Half Size Radiator
* OBD1 Distributor (brand new)
* OBD0-OBD1 Distributor Conversion Harness
* OBD0-OBD1 ECU Conversion Jumper Harness
* OBD1 Crome Chipped P28 ECU (tuned)
> Blox Racing Tuner Series EG/DC Coilovers - $500.00
> Skunk2 Polished Lower Control Arms - $150.00
> HX Wheels w/ Brand New Tires - $400.00
> Blox Racing Exhaust EF CRX - $250.00
> Complete Shell CLEAN TITLE (no coilovers, lcas, or wheels/tires) - $1000.00
OR...
PURCHASE THE ENTIRE CAR FOR $5000.00
1 - 3 of 3 Posts
