1 - 20 of 73 Posts
PAG 3 - NEWS - ** Ultimate Street Stroker Build **
Hi guys,
So its time for me to start my build.
As some of you know i Own a Euro Type R, aka FN2.
So far I just have bolt-ons, did plan to install cams a wile back but didnt go as planned and i stoped everything for nearly 2 years.....
... Finaly decided to get back on my feet and start the build i had thought about for a long time.
I did consider a K24 block and i do know that would be a better/cheaper choice, but i fancied a diferent route.
One of my K20Z4 blocks has just been sleeved this week, so soon things will start to roll a bit smoother.
This is a street car, to be run in pump fuel. Ocasional Track days.
So, this is the build:
Block
K20Z4
Dartons sleeves
ERL 96mm Crank (Modified OEM 99mm)
JE 89mm 12.5 CR Custom Pistons
Carrillo Custom A-Beam rods
ERL S2000 oil Pump
K24 Steel Sump
Head
Tean4Piston 156 CNC RBC Head
Ferrea 6000 Valves
SVM 312 Cams
4PR PAC Valve Spring Kit - Tool Steel Retainers - Viton Valve Seals
RRC IM CNC Ported by Endyn
TL-SH AWD TB
3.5" intake
TODA Headers
3" Exhaust
OKADA Projects Coil Pack
Transmission
FN2/FD2 Gear Box and Final Drive
Quaife LSD
TODA Racing Flywheel
TODA Racing High Power 6 Puk Clutch
Chassis
KW Variant 3 Coilovers
SPC Camber Bolts
J's Racing C-Pillar bar
J's Racing Floor bar
J's Racing Fender Braces
AP Racing BBK 4 Pot 330mm discs w/ Ferodo DS2500 up Front
StopTech Discs w/ Ferodo DS2500 Rear
StopTech Brake Lines Front / Rear
Volk Racing TE37 18x8.5 w/ RE050a 225/40 tires - Daily Drive
Advan Racing RZ 17x8 w/ Toyo R888 235/40 Front and 215/45 Rear - Track
Will post pics soon.
Alot of you guys help me get this far and im sure i will still need alot of your help.
Thanks
Regards
Paulo
Why a modified crank? Either use a 92 or 99
Honestly.., I wanted bigger then 92mm, so without going for a "proper" custom crank (lots a money) I was left with OEM 99mm.
Realy, I compromised on the 96mm over the 99mm for the sake of a litle better r/s ratio, a litle beter rod angle there for a litle more safe revs...
Am I going the wrong way?
I just see modified cranks as one more potental areA for failure
I see where you are coming from. I feel that the modifications to a 99mm crank in order to de-stroke it do not put the reliability of the crank at risk.
Its a OEM crank and its also balanced when the work is being done.
We dont hear many OEM cranks giving in (in acceptable driving conditions).
This is not a drag car, and despite the fact i would like to see 8800 rpms, and i realise this could be a tad high, I wont be hitting the rev limiter for long periods of time.
Nice setup. Looking forward to seeing pics. :popcorn:
Thanks mate. :silly:
Those pistons I showed ya were intended for 9k+ with a 99 crank for a drag car.
I think you can do whT you want with the 99 crank. And they ain't thay bad. Last time I shipped one to Russia it was like 75 usd which want that unreasonable.
Discussion Starter · #8 ·
Those pistons are the choice... thats why CR went down from 12.5 to 12.2.
lol..., do you have any more at 75usd? :silly:
Discussion Starter · #10 ·
That was shipping. My point.was cranks are.cheap.even to Portugal. I'm assuming you Re on the euro. $200 usd is like free to you.
Sorry mate... tought that was cheap!!
Euro sucks at the moment bro.... and dont know if its going to last much longer!
The crank, de-stroked to 96mm and balanced should be around the 600 usd mark...
Discussion Starter · #16 ·
Hi,
So after hitting a few snags, and after ALOT of calculations, we are back on track. :silly:
Custom pistons ordered, once these arrive, we move to the rods. :up:
In the mean time and wile we wait for the juicy stuff, heres some pics of whats already here:
OKADA Plasma Direct
RDX Injectors & Clips
J's Racing Chassis Bars
J's 25mm Floor bar
J's C-Pillar Bar
J's Fender Braces
AP Racing Front Kit
4 Pot Caliper
330mm Discs
Stoptech Front Brake lines
Full Brake Set-up
- AP Racing 4 pot Calipers
- AP Racing 330mm discs
- AP Racing Front Pads
- AP Racing Oil
- StopTech Front Brake lines
- StopTech Rear Discs OEM Size
- Ferodo DS2500 Rear Pads
- StopTech Rear Brake Lines
More to follow.
what piston u guys talking about? don't leave us in the dark :p
1 - 20 of 73 Posts
