I also "heard" that its a good idea for something like autox.NemesisSi said:The lighter the fly wheel the faster you will fall out of VTEC. You should only switch to a lighter fly wheel when you are going FI to help spool up your boost.
If your gonna just do autox then yes it probably would be a good idea since your gonna stay in 2nd most of the time. Youll be able to "hold" a gear better. But if you move into road racing or drag racing then you run into the prob of falling out of VTEC too fast when you upshift.V8KO said:I also "heard" that its a good idea for something like autox.NemesisSi said:The lighter the fly wheel the faster you will fall out of VTEC. You should only switch to a lighter fly wheel when you are going FI to help spool up your boost.
NemesisSi said:If your gonna just do autox then yes it probably would be a good idea since your gonna stay in 2nd most of the time. Youll be able to "hold" a gear better. But if you move into road racing or drag racing then you run into the prob of falling out of VTEC too fast when you upshift.V8KO said:I also "heard" that its a good idea for something like autox.NemesisSi said:The lighter the fly wheel the faster you will fall out of VTEC. You should only switch to a lighter fly wheel when you are going FI to help spool up your boost.
My mom told me that running a lighter flywheel can make you impotent. And I know for sure that it will make your face "freeze like that" it happened to my friendAndrie said:NemesisSi said:If your gonna just do autox then yes it probably would be a good idea since your gonna stay in 2nd most of the time. Youll be able to "hold" a gear better. But if you move into road racing or drag racing then you run into the prob of falling out of VTEC too fast when you upshift.V8KO said:I also "heard" that its a good idea for something like autox.NemesisSi said:The lighter the fly wheel the faster you will fall out of VTEC. You should only switch to a lighter fly wheel when you are going FI to help spool up your boost.
I vote this post as post of the month! LOL
