1 - 5 of 5 Posts
I need to know the size of tap to buy to rethread the holes in my crank for the flywheel bolts, apparently i didnt tighten the flywheel down enough and messed the threads up some. Ordered new bolts but couldnt find the exact pitch to order a tap any one know it?
I don't know if you can safely retap due to the size/shape of most tapping tools. You might have to go with a helicoil.
If by chance the crank is out of the car, then as previously suggested, I would probably try to find a new crank. However I'm very particular about things like that.
1 - 5 of 5 Posts
