1 - 5 of 5 Posts
are they interchangable..i searched but found no definite answer on the flywheel question. just need conformation on both.
IMAKEBOOSTATIDLE
you cant run a type s clutch with a EP3 Flywheel.... You need a Type S clutch and Type S Flywheel.
so you're saying 6 speed flywheel on work on 5 speed clutch and the opposite,but can you run a 5 speed setup on a six speed tranny or reverse of that
IMAKEBOOSTATIDLE
you need a 6 speed clutch and flywheel... make sense? you cant use a 5speed clutch on a 6 speed flywheel
1 - 5 of 5 Posts
