made it to the track this weekend. k20a in a eg hatch, with intake, DTRFAB header, and k pro, managed to pull a [email protected] with a 1.86 60 ft. going for more tuning. then hitting the track again.
23inch slicks.909edge said:nice times... what kinda tires?
the 60ft aint all that great. 2 step. rev and slip the clutch on the way out.909edge said:ok cool - how'd you launch it? cuz i'd be stoked to get a 60 ft like that.
218whp when i hit the times. the car has some more in it. hoping for 225whp like i was saying. the 218whp was only one hour of tuning, and each pass on the dyno it gained a hp or two. cross the line in 5th. pretty crazy, what gear do you finish in?non vtec said:How much power do you have???
Also what gear do you cross the line in??
better than i pullallmtrallday said:the 60ft aint all that great.
I used to end in 5th in the EP when I ran 22" slicks, but now I run 23's so I don't have to go to 5th. In the EK I only go to 4th on 22's.allmtrallday said:cross the line in 5th. pretty crazy, what gear do you finish in?non vtec said:How much power do you have???
i was running the 23s too, but ended in 5th.1fstEP3 said:[
about the same amount of power, you use bigger slicks and have a lighter car. is that 1800lbs with you in it? thats pretty damn light. mine is at 2170 with me in it.non vtec said:The last meet I ran at I stayed in 4th but I actually am about half way through 5th.. I run 24.5-9-13's..
Last meet was on a cold as track as we are at the end of winter over here.. Only ran a 1.97 60ft instead of the usual sub 1.8's But still managed to pull a 12.42 @ 113mph with about 30-60metres on the limiter in 4th... I was only doing exhibition passes and it was only really 60ft testing...
I run about 215whp with 156.6 ftlbs... but my hatch is probably sub 1800lbs on the track.. I also run a Stock JDM K20A with JDM 6spd
good luck bro. let us know what happens.non vtec said:yeah that 1800 with me in it... I will be running a full competetion meet on the 23rd or 24th of October I cant remember which The sunday :lol: .. Hopefully will run a low-mid 11... Our current all motor record sits at an 11.60 so hopefully I can beat that..
