1 - 5 of 5 Posts
· Banned
Sorry to say but not a big fan of teins. Have owned two sets, didn't like them too much. I would recommend the classic Koni Yellow/Ground Control setup...
If you are serious about the road course part, Koni is releasing some new shock with better valving for stiffer springs/roadrace stuff. Should cost about $1000. Run those with ground control 400 front/600 rear...
another good choice is Progress, they make good coilover sets for EF about $1400.
Koni Yellow/Ground Control setup is probably the best way to go.
On my EG I've had koni yellow/H&R race, koni yellow/H&R sport, and koni yellow w/KGMM race springs (which I've been using for the last year and half, great setup, springs are discontinued though), I also used tanabe ITR coilovers. I like the koni yellow w/KGMM race spring setup the best, and all setups were used on the track and street.
I also have spoon lower tie bar, SRR lower control arms and generic strut tower braces, stock 22mm front sway, and ITR 22mm rear sway, after about 5 setups I came up with this one and am very happy with it.
· GoldStar
why is that? did you use the manufacture's recommended settings then tune from there. i own a set of teins and they're killer at streets of willow springs.
1 - 5 of 5 Posts
