1 - 7 of 7 Posts
If you do not see the information you are looking for here, check the Stickied threads in the Subforums. If you do not see what you are looking for, you can search the entire site, or narrow the search to a specific subforum. It is best to ask a question in a related thread, this keeps the information organized and it also helps others find information in older threads.
If you would like to contribute, just post it up. Show us what you got too, pics are what we need the most:up:
If you need pics hosted/resized, PM me.
2002-2003 RSX FSM -sspem2 <<<<Right Click, Save As :up:
Or you can buy it here HelmInc.com
More FSM's here: CLICK ME!
Even MORE FSMs here
FAQ-----------------------------------------------------------------------------
Be sure to check out these great write-ups from fellow K20A.org members
blackEK
  • Swaps
Where To Buy a K20A? -lucky_marco_55
I want to use an 07 Si (K20Z3) motor and tranny for my swap... -matt96ex
Where To Buy Swap Parts? -Vendor Section
Identify and disect/label K20a2 motor! Pics inside!! -Hybrid93Hatch
What parts do I need? **SWAP PARTS LIST: The thread to end all the questions.** -Froth
Can I use RSX axles with my EG swap? OEM combo? -Karcepts
EKK1 vs EKK2 FAQ -drhonda
Hasport EKK2 mount clearance problems with Intregra/DC2 PS Rack? -kommon_sense
DA swap information? -JDM809
  • Engine
Honda/Acura Part Number List
Which o2 sensor can I use?
Which spark plugs do I use? -chameleon
What Crank Pulley should I use? -suprfast
Type S head ..... uses dual valve springs? -amwerx
What are the differences in the K20 throttle bodies? -nikos
What is the difference? K20A vs F20C -duckmanEG
What is the difference? K20A2/K20A3 blocks -ventuli
What is the difference? K20A2 vs K20Z1 -EK-FireMan
...and the K20Z3? -matt96ex
Port on the K24A2/K20Z3 head? -null
K-Series shifter cables compatible??? -BORN-EK
Official oil pan ground clearance & Axle angle PICTURE Thread! - Fuster_Cluck
What header is best for me? Let's chat Header Design, Fabrication and Terminology 101 -Ekasey
Putting head on block / lubrication head studs -nikos
What is the recommended max safe boost on a K20/K24? -boostedGSR-Si
Nitrous setups -JasonMann
Loopy Idle? -Tommy
Teach me about injectors
How do I use RDX injectors (pn:16450-RWC-A01) on my K20/24? -geoscranny84
Information on 3 pulley setup! -Droppedcrxsi
Type S Valve Spring Seat Differences? -JustinD
Valve stem, Retainer/Cotter? Which do I use? -Theta
What is the revised keeper/retainer design on 04-06 heads? -rsxmachine
How to recognize Type R cams -supafly
06 TSX cam vs DC5R cam comparison pics inside! -katman
How do K24A1 (CRV) rods compare to K24A2 (TSX) -Scourge
S2000 piston vs TSX piston in K24 block, look and see... -98specR
K20A2 Baffled Oil Pan Suggestions? -kommon_sense
Modified S2000 oil pump general info from ERL -carl
S2000 oil pump-windage tray? -SchueString Racing
oil pan/oil pump/engine block compatibility list -k20eg6
K20 vs K24 oil pan and dipstick -StErN
A1/2/3/4 vs K20Z3 oil pump -talonxracer
Delete Heater Core? -jenkinsK
Retain Heater Core? -Scourge
  • Transmission
Clutches: types, materials, and components. -xproductionz
Correcting improper clutch geometry -talonxracer
Shift cable doesn't reach on trans? -Paul1985
Shift Arm Interchangeability -PapiTuyo326
What is an LSD and what does it do?
What is the difference between the 02-04 and 05-06 VSS? -Hondata
Some info/help needed with 05 speedo -AwdEi
LSD Install problems...I can't seem to get the tranny cover back on? -2000Accord5sp
OEM Honda axles? -C-speed
  • Body/Chassis
How do I install Shifter & cables? Install pics here - Progger
How do I install the shifter box...what are the differences? -Karcepts
What mods are needed to make the Karcepts mounting kit fit in a Del Sol? -Karcepts
What mods are needed to make the Karcepts mounting kit fit the EF chassis? -Karcepts
What will my Engine Bay look like? Where do the wires go in a tuck? -nikos
  • Electronics/Wiring
List of Shops/People for Tuning
AEM vs Hondata: the rumors, the difference, the truth -DWCHKYPMP20
What ECU's can be K-pro'd? -Hondata
What are the differences? -Hondata
Manual RSX VS Auto RSX engine harnesses -H2nr
RSX Type S k20a type r ECU PINOUT -nikos
How do you street tune? How do you use K-pro? -Hondata
Can someone explain to me the values of the VTC on K-pro???? -chunky`
2005 Type-S ECU Pin-Out Help -eK24monster
K-Pro Tuning and FAQ, TONS OF INFO -conrad
KPro & ECU questions answered -GST2RSX-S
Where do I drill to tuck my main harness? -StErN
Post your Wire tucks/ battery fuse box locations -tibbie 03
Cool DIY-------------------------------------------------------------------------
  • Swaps
K20a2 into 95 Vx build - Over 1,000 working pics - Fuster_Cluck
How-To: K20 into 92-00 Civic/Integra -poison
DIY K20 Swap into a 1988-1991 CRX/Civic (EFK1 Hasport Mounts) -CRXBart
K24A2 into 1992-1995 Civic (EGK1 Hasport Mounts). Tech Questions Asked/Answered Here -litterbox
98 Civic EX K20 Swap (EKK2 Hasport Mounts 1996-2000 Civic) -kommon_sense
K20A2 EK Swap (EKK1 Hasport Mounts 1996-2000 Civic) Parts List, Pictures, Manual Conversion and Writeup in Progress -boost me
K20 EK9 complete build (Hybrid Mounts) -TypeOne
DIY: K20/K24 Swap into a 2001-2005 Civic (ESK1 Hasport Mounts) -xproductionz
  • Engine
Install a Hondata Intake Manifold Gasket -Rallyeman
How to lock VTC at 50 degrees -DCK24
A brief tour of how to check clearances in your motor -chunky`
HOW TO INSTALL CAMS by K series.com -rsxmachine
Supercharger + Nitrous: A Users Guide -Oside Jimc
How to Build a block : Excellent Info -Jeff Evans
DIY: Modify K-Series Injectors to flow 490cc and 520cc -xproductionz
FUEL SYSTEM PARTS LIST -nikos and NickZED
DIY: How to make fuel lines -blue92da
Reusing the stock fuel rail fitting - [How To: Pic intensive] -Froth
Use TSX mani on a K24A1 -Froth
How To: Electro Hydraulic Power Steering -Rubber Chicken
How to take off the K20 Intake Manifold -sspem2
In-Car Headswap, Semi How-To. K24/20 Frank -Froth
P/S into K20 EG Writeup -Karcepts
P/S into K20 EK Writeup -drhonda
DIY: Oil Catch Can for Under 20 Bucks -98specR
DIY:K-Series Camshafts Installation -rsxmachine
K24a2 meets Type S Oil Pump w/pics -suprfast
  • Transmission
How to convert a 05-06 to 02-04 -SuperThanh
Type-R LSD install into EP3 tranny -2000Accord5sp
DIY:Transmission Rebuild 6Speed Picture Thread -palmerblock
DIY: Turn a 5 spd transmission into a 6 spd transmission -nikos and FearlessDSM
How-To: Element 6 speed conversion -rhurt
DIY: Install a B-series LSD into an K-series 6spd -SpeedDreamz.com
  • Body/Chassis
05-06 RSX Taillight Convesion HOW TO + Part List. Visual Guide -Reactionsi
DIY: Polished RBC -talonxracer
How To: sound deadening material removal -suprfast
Energy Suspension Installed w/Grease Zerks -sevndustn
My brake system write-up. get comfortable. -blackEK
How to put "X" brakes on your car -BrakeExpert
Must Read If You Want DIY Wiring!!! -SuperThanh
DIY: Coolant sending unit with Kpro -Paul1985
Injector Resistor Box Install Guide -Oside Jimc
How to listen to your knock sensor to listen for REAL vs FAKE knock -Razathorn
DIY Det Can w/free Freq Analyzer Software -Tsumetai_Kokoro @PGMFI.org
Theroswitch and Temperature Sending Unit -Karcepts
DIY: Wire Tuck!!! -SVOboy @ GasSavers.org
Simple wiring harness write-up for EG -kazino42
How to repin the K24A2 and K24A4 CRK sensor for the K20 Engine Harness -2000Accord5sp
HOW TO: Making a "Secondary Key" Anti-Theft Device -Froth
Frank Info-----------------------------------------------------------------------
LOTS OF K FRANK INFO -Kevin
Timing chain experiences 101 -chameleon
K20-K24 Frank Build -Thang
Which Head Studs to use? -SinisterCivicSi
The Definitive K20/24 Sensor Comparison -Froth
Water pump differences.... (k20a2/k24a2) clarified -HotWheelz
K24/K20a2 head- which water pump to use? -SiFreak
Difference between TSX and RSX-S Head? -highrevnef
wow great thread nice job guys! :)
1 - 7 of 7 Posts
