Fixed...http://www.k20a.org/forum/showthread.php?t=84843
figure out why your thread is'nt following these and fix it.
It will fit a 16" inch for sure and according to the Wilwood web site it fits certain 15" wheels.....What's the minimum rim size that will fit these bad boys?
My brakes did not come with a template, but I believe the Wilwood website does...search for it there.Is there a template to see which wheels might fit?
Ill see if I can find something. What size rims are you trying to fit them onto??Is there a template to see which wheels might fit?
Nice brakes...I have the same ones in red on my car. I did not see it, but are you including all the washers/spacers as well?
Thanks!My brakes did not come with a template, but I believe the Wilwood website does...search for it there.
Oem 97-01 15" itr wheels. I'm guessing im going to need new brackets?Ill see if I can find something. What size rims are you trying to fit them onto??
I comes with everything you need to install them onto a 02-06 Acura RSX...
Thanks!
i cant see them fitting under a 16" rim. on mine there is barely enough space 2 fit a finger between the caliper and wheel.
Heres a old pic of a 16" wheel mounted on my car with the brake kit....
12.1....What size are the rotors?
Sent from my Nexus 7 using Tapatalk HD
Haha thanks....Nice yellow errr gold wheel!:new_slayer: Good luck with the sale bud!
