1 - 20 of 26 Posts
f/s 1991 honda civic si - k20z3 swap PICS. $4k
1991 honda civic si hatch (project)- teal - ext., black - int., hasport mounts, rsx base axles, aem fuel pressure regulator, hx wheel, 06 si shifter & cables, 06 si muffler, new oem fuel filter, dc sport header - heat wrapped, rear disc brake conversion, -6an fuel fittings, earl fuel hose, walbro 255 fuel pump, k20z3 swap low mileage, 06 si oem intake, clean interior, exterior has some dents. I have started this project but have ran out of money to spend on it. It only needs a couple of more items to get it going. The motor is installed and is turning over, but it will not crank. The keys need to be programmed to the ecu. I also have all the a/c parts, so a/c can be installed. All you will need are a couple of custom lines and you can get them made a Godmans here in town. I would love to keep it and finish it, but I have to move on.
$4000 as is. - I want this gone!!!!!!!!!!!!!!!!!!!!!!!!!!!!
trades - 98-02 toyota 4x4 tacoma truck in good condition. color does not matter
99-00 civic si - color does not matter
02-04 civic si - color does not matter
honda s2000 parts
1 - 20 of 26 Posts
