debating if what i should do? any recommendations? Turbo application, have a turbo manifold, 3.5in hood exit exhaust and two 1.75in hood exit dump tubes i am going to do
I've asked this and was always told it'll retain too much heat and possibly damage the item. Not sure if that's true,but it seems possible.Why not get it coated AND wrap it? I would imagine this would offer superior heat control than either method alone.
When you wrap the header, make sure you soak the wrap first...this allows you to stretch the fabric during install. Otherwise, the fabric will expand and loosen on the header after install.
I also heard somewhere that this was the reason why FR was not honoring warranties on heat wrapped products, not sure if there policies have changed.I've asked this and was always told it'll retain too much heat and possibly damage the item. Not sure if that's true,but it seems possible.
Looking at Pics on their website, they show plenty of their manifolds heat wrapped. Guess this is no longer the case..I also heard somewhere that this was the reason why FR was not honoring warranties on heat wrapped products, not sure if there policies have changed.
Soooooo Header or Volcano wrap? They both say they are used for exhaust, I'm wondering what the difference is.
The radiator fan has nothing to do with your IAT's. They will vary more depending on the outside temperature and filter placement than anything.A lot of he say she say going on. My header is currently wrapped and still under hood temp is HOT. Like you open the hood and you have to look away hot. But iat readings are fine. While moving I see as low as 60* but while idling for a bit. I see it go up to 122* but then fan kicks on a it drops it a little.
Id like to try a coat the inside of the piping but I dont have a spare header during downtime. And also make heat shield to try and solve this heating issue.
