One reads if the clutch is fully pressed which then allows starting. The other reads if the clutch is fully released which allows for cruise control. That is all they are used for.Do one or both of those switches need to be connected for it do drive correctly or are they just to make sure that it won't crank without the clutch pushed down? Not sure if these ECUs use clutch position for something.
