Just did K20 R into EK. How do I check Error codes? Is it the same as before?
P P_TAN · Registered Joined Feb 17, 2005 · 9 Posts Discussion Starter · #1 · Mar 4, 2005 Only show this user Just did K20 R into EK. How do I check Error codes? Is it the same as before?
fearless_dsm · Registered Joined Mar 22, 2004 · 414 Posts #2 · Mar 4, 2005 Only show this user Do you have a datalink connector wired up?
nikos · Banned Joined Aug 2, 2003 · 15,811 Posts #3 · Mar 4, 2005 (Edited) Only show this user If you have a obd2 datalink hooked up, just use a jumper wire or metal paper clip... I think you know the rest of the long flashes and short flashes.
P P_TAN · Registered Joined Feb 17, 2005 · 9 Posts Discussion Starter · #4 · Mar 7, 2005 Only show this user Thanks, wheres this data link found?
nikos · Banned Joined Aug 2, 2003 · 15,811 Posts #5 · Mar 7, 2005 Only show this user On the eg/ek/dc2/ef hybrids , it is on the pnp harness.. On the 2002+ Civic SI it is under the driver's side dash In the RSX, it is by your right knee.
